주요 콘텐츠로 건너뛰기
WowWee MiP Robot Battery Replacement
필요한 것
  1. WowWee MiP Robot Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 WowWee MiP Robot Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Battery Replacement: 2 단계, 이미지 2개 중 1개 WowWee MiP Robot Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Moira Keahon
회원 가입일: 09/24/14
257 평판
안내서 3개를 작성함
University of Maine, Team 1-50, Diaz Fall 2014 University of Maine, Team 1-50, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G50
3 회원들
안내서 6개를 작성함
14가이드 댓글
Its a programmer MIP not this kind.
Azariah Trumble - 답글
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
Gil Acosta - 답글
does spare battery adapter vailable(not reachargeable)
coolboyz' channel - 답글
Coder Mip Battery says fully charged - but Coder Mip doesnt turn on?
Sadie - 답글
Coder MiP one day old - was working - battery says fully charged - but Coder MiP doesn’t turn on? Any suggestions?
Sadie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 89
전체 시간: 13,335
