주요 콘텐츠로 건너뛰기
이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 1 단계, 이미지 1/2 : 1 단계, 이미지 2/2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 2 단계, 이미지 1/2 : 2 단계, 이미지 2/2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Moira Keahon
회원 가입일: 09/24/14
257 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-50, Diaz Fall 2014 University of Maine, Team 1-50, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G50
3 회원들
안내서 6개 작성하였습니다
댓글 11개
Its a programmer MIP not this kind.
Azariah Trumble - 답글
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
Gil Acosta - 답글
does spare battery adapter vailable(not reachargeable)
coolboyz' channel - 답글
Coder Mip Battery says fully charged - but Coder Mip doesnt turn on?
Sadie - 답글
Coder MiP one day old - was working - battery says fully charged - but Coder MiP doesn’t turn on? Any suggestions?
Sadie - 답글
Brand new Coder MIP - fully charged (approx. 20 hours charging time) after 5-7 minutes in use, it run out of battery already. Is this normal?
Barbe _74 - 답글
Brand new Coder MiP (fully charged for approx. 20 hours) runs out of battery after only 5-7 minutes in use. Is this normal?
Barbe _74 - 답글
Same CODER MIP here - we got erratic performance from the battery pack. A smart slap seems required to ensure a tight battery connection after a robot fall, otherwise it appears to have run out of battery. Not optimal, but it allowed us to play for a while.
dagmarfraser - 답글
My Mip doesn’t work even if I replace the batteries. It acts very strange. It keeps making a clicking noise
Daniel Cleiland - 답글
I have A Coder MiP instead of a plain MiP
Are there different instructions.
Clarrie O'HARE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 39
전체 시간: 12,325
