주요 콘텐츠로 건너뛰기
WowWee MiP Robot LED Light Replacement
필요한 것
  1. WowWee MiP Robot LED Light Replacement, Battery: 1 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot LED Light Replacement: 2 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot LED Light Replacement, Wheel: 3 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement, Wheel: 3 단계, 이미지 2개 중 2개
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot LED Light Replacement: 4 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot LED Light Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: 6 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: 6 단계, 이미지 2개 중 2개
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot LED Light Replacement: 7 단계, 이미지 3개 중 1개 WowWee MiP Robot LED Light Replacement: 7 단계, 이미지 3개 중 2개 WowWee MiP Robot LED Light Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot LED Light Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot LED Light Replacement, LED Light: 9 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement, LED Light: 9 단계, 이미지 2개 중 2개
    • Remove the four 7.5mm Phillips #1 screws.
  10. WowWee MiP Robot LED Light Replacement: 10 단계, 이미지 2개 중 1개 WowWee MiP Robot LED Light Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully pull the motor and motherboard assembly straight out from the base.
    • Be careful not to break the plastic rods that go through the motor assembly and are connect to the shell.
  11. WowWee MiP Robot LED Light Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the precision tweezers to unplug the bundle of wires.
  12. WowWee MiP Robot LED Light Replacement: 12 단계, 이미지 1개 중 1개
    • Slide the head back to separate it from the body.
    • The motherboard does not need to be separated from the head to replace the LED light.
  13. WowWee MiP Robot LED Light Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the 7.5mm Phillips #1 screw.
    • The LED light is soldered to the small circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Courtney
회원 가입일: 02/04/16
236 평판
안내서 1개를 작성함
USF Tampa, Team 3-4, Wollert Spring 2016 USF Tampa, Team 3-4, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 779
