주요 콘텐츠로 건너뛰기
WowWee MiP Robot Power Switch Replacement
필요한 것
  1. WowWee MiP Robot Power Switch Replacement, Battery: 1 단계, 이미지 2개 중 1개 WowWee MiP Robot Power Switch Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: 2 단계, 이미지 2개 중 1개 WowWee MiP Robot Power Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: 3 단계, 이미지 2개 중 1개 WowWee MiP Robot Power Switch Replacement, Wheel: 3 단계, 이미지 2개 중 2개
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot Power Switch Replacement: 4 단계, 이미지 2개 중 1개 WowWee MiP Robot Power Switch Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: 6 단계, 이미지 2개 중 1개 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: 6 단계, 이미지 2개 중 2개
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: 7 단계, 이미지 3개 중 1개 WowWee MiP Robot Power Switch Replacement: 7 단계, 이미지 3개 중 2개 WowWee MiP Robot Power Switch Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: 9 단계, 이미지 2개 중 1개 WowWee MiP Robot Power Switch Replacement, Power Switch: 9 단계, 이미지 2개 중 2개
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Daniel Burkholder
회원 가입일: 02/16/16
623 평판
안내서 4개를 작성함
USF Tampa, Team 3-4, Wollert Spring 2016 USF Tampa, Team 3-4, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G4
4 회원들
안내서 10개를 작성함
1가이드 댓글
where can i buy the power switch of MiP
Reinejoe Cacho - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 787
