소개
The power switch turns the MiP on or off. If it's malfunctioning the robot will not work.
필요한 것
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
다른 2명이 해당 안내서를 완성하였습니다.
