주요 콘텐츠로 건너뛰기
WowWee MiP Robot Tire Replacement
필요한 것
  1. WowWee MiP Robot Tire Replacement, Wheel: 1 단계, 이미지 1/2 WowWee MiP Robot Tire Replacement, Wheel: 1 단계, 이미지 2/2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  2. WowWee MiP Robot Tire Replacement: 2 단계, 이미지 1/2 WowWee MiP Robot Tire Replacement: 2 단계, 이미지 2/2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Tire Replacement: 3 단계, 이미지 1/1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  4. WowWee MiP Robot Tire Replacement, Tires: 4 단계, 이미지 1/2 WowWee MiP Robot Tire Replacement, Tires: 4 단계, 이미지 2/2
    • Remove the three 7.7 mm Phillips #1 screws.
  5. WowWee MiP Robot Tire Replacement: 5 단계, 이미지 1/3 WowWee MiP Robot Tire Replacement: 5 단계, 이미지 2/3 WowWee MiP Robot Tire Replacement: 5 단계, 이미지 3/3
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Moira Keahon
회원 가입일: 09/24/14
257 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-50, Diaz Fall 2014 University of Maine, Team 1-50, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G50
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
my MiP has plastic over his wheels
Clarrie O'HARE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 5,818
