소개
This guide is designed to help users remove MiP’s wheels. MiP has two wheels that are connected to its body with screws. If the wheels need replacement or cleaning, follow this guide.
필요한 것
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
Separate the rubber tire from the rim.
Push the collar out to separate the plastic layers of the wheel.
다른 5명이 해당 안내서를 완성하였습니다.
The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
donna.hester7 - 답글
