소개
This guide shows you which screws and which pieces to remove in order to access the wheel housing.
필요한 것
Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
