소개
The Wyze Cam V2 comes with a charging port that allows you to power your device. If your charging port starts having charging problems you might need to replace it. This guide will help you through the steps of replacing it.
필요한 것
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
이 단계에 사용된 도구:Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
Carefully remove the motherboard from the device.
