주요 콘텐츠로 건너뛰기
Wyze WVCR200s Bumper Replacement
필요한 것
  1. Wyze WVCR200s Bumper Replacement, Side Brush: 1 단계, 이미지 1/1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Bumper Replacement: 2 단계, 이미지 1/1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
  3. Wyze WVCR200s Bumper Replacement, Bumper: 3 단계, 이미지 1/1
    • Flip the vacuum over.
  4. Wyze WVCR200s Bumper Replacement: 4 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the six screws along the bottom edge of the bumper.
  5. Wyze WVCR200s Bumper Replacement: 5 단계, 이미지 1/3 Wyze WVCR200s Bumper Replacement: 5 단계, 이미지 2/3 Wyze WVCR200s Bumper Replacement: 5 단계, 이미지 3/3
    • The small plastic connector holding the bumper in place should now be loose. Make sure it's disconnected.
    • Pull the bumper straight off of the vacuum.
결론
Brandon Amado
회원 가입일: 03/20/23
411 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-5, Ramos Spring 2023 UMass Dartmouth, Team 5-5, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 103
