주요 콘텐츠로 건너뛰기
Wyze WVCR200s Rotating Brush Replacement
  1. Wyze WVCR200s Rotating Brush Replacement, Rotating Brush: 1 단계, 이미지 1/1
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Rotating Brush Replacement: 2 단계, 이미지 1/2 Wyze WVCR200s Rotating Brush Replacement: 2 단계, 이미지 2/2
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Rotating Brush Replacement: 3 단계, 이미지 1/3 Wyze WVCR200s Rotating Brush Replacement: 3 단계, 이미지 2/3 Wyze WVCR200s Rotating Brush Replacement: 3 단계, 이미지 3/3
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
결론
Brendan
회원 가입일: 03/20/23
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-5, Ramos Spring 2023 UMass Dartmouth, Team 5-5, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 176
