주요 콘텐츠로 건너뛰기
X-Treme Tablet Generation 2 Motherboard Replacement
필요한 것
  1. X-Treme Tablet Generation 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Remove the cover from the back of the tablet. Using the pick tool, pry the cover the case. Do this by starting in the upper corner, working around the edges until the cover unclips from the case.
  2. X-Treme Tablet Generation 2 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Find and detach all of the connections to the motherboard. Remove the connections while leaving the components in place from the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Remove the connections using a soldering iron and desolder pump to remove the current soldered connections.
  3. X-Treme Tablet Generation 2 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 X-Treme Tablet Generation 2 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Replacing the defective motherboard with a functional motherboard: Reattach the connections at the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Reattach the connections by soldering them back onto the motherboard using a soldering iron.
결론
작성자
5다른 기여자 명과 함께
Dalton Croslow
회원 가입일: 11/10/18
97 평판
안내서 1개를 작성함
IUPUI, Team S3-G3, Wilson Fall 2018 IUPUI, Team S3-G3, Wilson Fall 2018 회원
IUPUI-WILSON-F18S3G3
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 315
