주요 콘텐츠로 건너뛰기
X-Treme Tablet Generation 2 Speaker Replacement
필요한 것
  1. X-Treme Tablet Generation 2 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Using a spudger and pry tool, remove the back cover. Start at the top corner, and carefully pry the back cover off of the main body.
    • Continue around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Speaker Replacement: 2 단계, 이미지 1/2 X-Treme Tablet Generation 2 Speaker Replacement: 2 단계, 이미지 2/2
    • Using a solder vacuum and soldering iron, release the red wire from the motherboard first, then release the black wire.
    • The speaker is held on the back cover with adhesive tape. Using a pry tool, carefully pry the speaker from the back cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kristen John
회원 가입일: 01/26/15
125 평판
안내서 1개 작성함
Pasco Hernando, Team 5-4, Prince Winter 2015 Pasco Hernando, Team 5-4, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G4
6 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 7
전체 시간: 324
