소개
The headlights illuminate while the car is moving forward, and can be useful for seeing the road ahead. A disconnected wire or blown light will make the light not die and will need replacing.
필요한 것
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unscrew the two 2.5 mm Phillips #00 screws from the underside of the car and remove the front underskirt.
다른 한 분이 해당 안내서를 완성하였습니다.
