소개
Replacing the system battery for this laptop is quite easy, as it is accessible externally and requires no screws to remove.
'Make sure to turn off your computer before performing the steps in this guide."
Remove the system battery.
Slide the battery latch release on the bottom of the computer in the direction of the #1 arrow. The access door will pop up.
Using your thumbs, slide the battery in the direction of the #2 arrow by inserting one thumb into the recess next to the battery access door and the other thumb into the indention surrounding the #2 arrow.
다른 한 분이 해당 안내서를 완성하였습니다.
