주요 콘텐츠로 건너뛰기
Xbox 360 E CD Drive Replacement
필요한 것
  1. Xbox 360 E CD Drive Replacement, Top Panel: 1 단계, 이미지 1개 중 1개
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E CD Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E CD Drive Replacement: 3 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement: 3 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E CD Drive Replacement, Wi-Fi Card: 4 단계, 이미지 1개 중 1개
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
  5. Xbox 360 E CD Drive Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
  6. Xbox 360 E CD Drive Replacement, Bottom Panel: 6 단계, 이미지 1개 중 1개
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  7. Xbox 360 E CD Drive Replacement: 7 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the spudger along the crevice to separate the grated face and the top body.
  8. Xbox 360 E CD Drive Replacement: 8 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement: 8 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  9. Xbox 360 E CD Drive Replacement, Top Body: 9 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement, Top Body: 9 단계, 이미지 2개 중 2개
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
  10. Xbox 360 E CD Drive Replacement, Bottom Body: 10 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement, Bottom Body: 10 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement, Bottom Body: 10 단계, 이미지 3개 중 3개
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  11. Xbox 360 E CD Drive Replacement: 11 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 11 단계, 이미지 2개 중 2개
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  12. Xbox 360 E CD Drive Replacement: 12 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement: 12 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  13. Xbox 360 E CD Drive Replacement: 13 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 13 단계, 이미지 2개 중 2개
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
  14. Xbox 360 E CD Drive Replacement, CD Drive: 14 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement, CD Drive: 14 단계, 이미지 2개 중 2개
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
  15. Xbox 360 E CD Drive Replacement: 15 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to unplug the blue and pink wires.
  16. Xbox 360 E CD Drive Replacement: 16 단계, 이미지 1개 중 1개
    • Lift the front end of the CD drive and take it out.
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
George
회원 가입일: 02/02/14
581 평판
안내서 1개를 작성함
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G11
4 회원들
안내서 44개를 작성함
댓글 11개
i wish the bottom cover magically came off like in step 9
sandjo - 답글
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Andrew Boyd - 답글
Several steps missing between 8 and 9
Freddie Parsons - 답글
Like remove wifi adaptor.
william capewell -
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Joe G. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 67
지난 30일: 179
전체 시간: 23,069
