주요 콘텐츠로 건너뛰기
Xbox 360 E RF Module Replacement
필요한 것
  1. Xbox 360 E RF Module Replacement, Top Panel: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E RF Module Replacement: 2 단계, 이미지 1/1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E RF Module Replacement: 3 단계, 이미지 1/3 Xbox 360 E RF Module Replacement: 3 단계, 이미지 2/3 Xbox 360 E RF Module Replacement: 3 단계, 이미지 3/3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E RF Module Replacement, Bottom Panel: 4 단계, 이미지 1/1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  5. Xbox 360 E RF Module Replacement: 5 단계, 이미지 1/2 Xbox 360 E RF Module Replacement: 5 단계, 이미지 2/2
    • Slide the spudger along the crevice to separate the grated face and the top body.
  6. Xbox 360 E RF Module Replacement: 6 단계, 이미지 1/3 Xbox 360 E RF Module Replacement: 6 단계, 이미지 2/3 Xbox 360 E RF Module Replacement: 6 단계, 이미지 3/3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  7. Xbox 360 E RF Module Replacement, Front Panel: 7 단계, 이미지 1/3 Xbox 360 E RF Module Replacement, Front Panel: 7 단계, 이미지 2/3 Xbox 360 E RF Module Replacement, Front Panel: 7 단계, 이미지 3/3
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  8. Xbox 360 E RF Module Replacement: 8 단계, 이미지 1/3 Xbox 360 E RF Module Replacement: 8 단계, 이미지 2/3 Xbox 360 E RF Module Replacement: 8 단계, 이미지 3/3
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  9. Xbox 360 E RF Module Replacement: 9 단계, 이미지 1/3 Xbox 360 E RF Module Replacement: 9 단계, 이미지 2/3 Xbox 360 E RF Module Replacement: 9 단계, 이미지 3/3
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    My actual disk tray came off the track looking into the best way to repair it
    David Mitchell - 답글
  10. Xbox 360 E RF Module Replacement: 10 단계, 이미지 1/3 Xbox 360 E RF Module Replacement: 10 단계, 이미지 2/3 Xbox 360 E RF Module Replacement: 10 단계, 이미지 3/3
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  11. Xbox 360 E RF Module Replacement: 11 단계, 이미지 1/2 Xbox 360 E RF Module Replacement: 11 단계, 이미지 2/2
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  12. Xbox 360 E RF Module Replacement: 12 단계, 이미지 1/3 Xbox 360 E RF Module Replacement: 12 단계, 이미지 2/3 Xbox 360 E RF Module Replacement: 12 단계, 이미지 3/3
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
  13. Xbox 360 E RF Module Replacement, RF Module: 13 단계, 이미지 1/3 Xbox 360 E RF Module Replacement, RF Module: 13 단계, 이미지 2/3 Xbox 360 E RF Module Replacement, RF Module: 13 단계, 이미지 3/3
    • Looking at the body of the device, locate the green panel to the right of the CD drive.
    • Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
    • Grip the middle of the green board and gently pull it out.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sarah
회원 가입일: 01/30/14
1,732 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G11
4 회원들
안내서 43개 작성하였습니다
댓글 2개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 57
전체 시간: 3,809
