소개
When you can't download the game you just have to have follow this guide to replace your Wi-Fi card.
필요한 것
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
Firmly grip the green Wi-Fi card and pull it out of the Xbox.
On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
