주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Xbox 360 Faceplate Replacement
필요한 것
  1. Xbox 360 Faceplate Replacement, Faceplate: 1 단계, 이미지 1/3 Xbox 360 Faceplate Replacement, Faceplate: 1 단계, 이미지 2/3 Xbox 360 Faceplate Replacement, Faceplate: 1 단계, 이미지 3/3
    • Orient the console horizontally with the I/O ports side down.
    • Insert the edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the Xbox.
    • Remove the faceplate from the front face of the console.
결론
다른 84명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,058 평판
안내서 619개 작성하였습니다
댓글 2개
Ok so my drive wasn't opening and i eventually came to the conclusion the drive was bad but i was wrong while replacing the drive the original one was plugged into the computer to obtain the drive key and it opened and closed fine, the problem is the case ...when i have the drive plugged into the xbox and tge actual xbox case is off it works once i put the case on it squishes the drive and it won't open, nothing appears wrong with any component. Help from anyone is appreciated
Societyburning - 답글
You don’t have to have tools for this.
brockchristian93 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 45
30일 전: 147
전체 시간: 28,770
