소개
This instruction manual will teach the user how to replace the CD Tray Belt. At the end the of this guide, the user should be able to replace the belt and reassemble the console. It is strongly recommended that you have some knowledge of the console, and perform the replacement in a well lit area.
필요한 것
Stand the Xbox up so the bottom part is facing up. Use your nail and poke at the second hole on the second row on the side of the Xbox.
The next hole is the twenty-first hole on the third row.
The final hole is the second to last hole on the fourth row. Repeat on each side, top and bottom.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Lol. Avoid drugs & alchohol or you could potentially make an err. Wow. Like the guide though! Thx.
