주요 콘텐츠로 건너뛰기
Xbox 360 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
  1. Xbox 360 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Peel the silver tape securing the optical drive to the metal casing.
  2. Xbox 360 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
  3. Xbox 360 Optical Drive Replacement: 3 단계, 이미지 1/2 Xbox 360 Optical Drive Replacement: 3 단계, 이미지 2/2
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
  4. Xbox 360 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Lift the optical drive assembly out of the metal casing.
결론
Walter Galan
694,492 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,683
