소개
There is no such thing as too much hard drive space, and nothing more frustrating than too little. This guide will show you how to replace your Xbox 360 S hard drive.
도구
지정된 도구가 없습니다.
부품
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
다른 94명이 해당 안내서를 완성하였습니다.
댓글 3개
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
no the os is on the internal drive all the hard drive is doing is adding more storge space
My hardrive says its unformated but its not and i dont want to loose content
