주요 콘텐츠로 건너뛰기
Xbox 360 S Wi-Fi Board Replacement
필요한 것
  1. Xbox 360 S Wi-Fi Board Replacement, Top Panel: 1 단계, 이미지 1개 중 1개
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Wi-Fi Board Replacement: 2 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 2 단계, 이미지 2개 중 2개
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
  3. Xbox 360 S Wi-Fi Board Replacement: 3 단계, 이미지 3개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 3 단계, 이미지 3개 중 2개 Xbox 360 S Wi-Fi Board Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Wi-Fi Board Replacement: 4 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Wi-Fi Board Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 5 단계, 이미지 2개 중 2개
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  6. Xbox 360 S Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 2개
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
  7. Xbox 360 S Wi-Fi Board Replacement: 7 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 7 단계, 이미지 2개 중 2개
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Wi-Fi Board Replacement: 8 단계, 이미지 1개 중 1개
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Wi-Fi Board Replacement: 9 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 9 단계, 이미지 2개 중 2개
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Wi-Fi Board Replacement: 10 단계, 이미지 2개 중 1개 Xbox 360 S Wi-Fi Board Replacement: 10 단계, 이미지 2개 중 2개
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Wi-Fi Board Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: 12 단계, 이미지 3개 중 1개 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: 12 단계, 이미지 3개 중 2개 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: 12 단계, 이미지 3개 중 3개
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi board out of the console.
결론
다른 38명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,199 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
5가이드 댓글
My Slim came without the wifi board, and subsequently without the holding screw.
Anyone know the thread, size, or depth of a replacement screw I could use to hold the replacement in? It seems like it won't go anywhere with the pseudo-USB connector in place, but I'd like to be positive.
Any help would be appreciated!
mattinnihon - 답글
Tuve ese mismo problema. Fui a una tienda y el técnico tuvo que quitarle la tarjeta de WiFi a otro xbox porque no hay repuesto
andreshgarcia20 - 답글
Worth noting.. Before you purchase a new wifi card, try taking it out and reseating it. Just had to do that with mine when the wifi suddenly stopped working. Once I pulled the card and put it back in, it worked beautifully.
Also, for clarification, you are opening the side OPPOSITE the side with the hard drive.
sarncadrill - 답글
Is it possible to replace it a newer, updated, improved WiFi card that is faster?
NoraTheSuccubus - 답글
My x box 360 didn’t come with Wi-Fi chip so what do I need to use my box online anyone please ?
Yusif yahiya Abdul Kareem - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 55
지난 30일: 205
전체 시간: 59,546
