주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xbox 360 수리는 저희 서비스 설명서를 사용하십시오.
  1. Xbox 360 Teardown, Hard drive: 1 단계, 이미지 1/1
    • Here you would usually have a hard drive, my xbox does not. To remove it you push down the button and lift it out
  2. Xbox 360 Teardown, Removing the front cover: 2 단계, 이미지 1/3 Xbox 360 Teardown, Removing the front cover: 2 단계, 이미지 2/3 Xbox 360 Teardown, Removing the front cover: 2 단계, 이미지 3/3
    • You can put a flat head screw driver in between the plastic as shown and gently pry open the front
    • You can alternatively grab inside the USB port and pull the cover off
  3. Xbox 360 Teardown, Removing the bottom panel: 3 단계, 이미지 1/3 Xbox 360 Teardown, Removing the bottom panel: 3 단계, 이미지 2/3 Xbox 360 Teardown, Removing the bottom panel: 3 단계, 이미지 3/3
    • Use a small tool to stick in and push these pins
    • Be sure to keep pressure pulling outwards for this to come out easily
    • Make sure that you pop out the pins on both sides
  4. Xbox 360 Teardown, Removing the top plate: 4 단계, 이미지 1/3 Xbox 360 Teardown, Removing the top plate: 4 단계, 이미지 2/3 Xbox 360 Teardown, Removing the top plate: 4 단계, 이미지 3/3
    • Same as the bottom plate you want to push in the buttons holding this in
    • Note that there are six buttons holding this together in total so it is ok to accidentally break 1 or 2
  5. Xbox 360 Teardown, The front case: 5 단계, 이미지 1/2 Xbox 360 Teardown, The front case: 5 단계, 이미지 2/2
    • You have to evenly disconnect all four of these connectors holding it together
    • I used flat head screw driver bits to hold the connectors open
    • You have to remove a warranty sticker to open the console. Be warned, this will void your warranty.
  6. Xbox 360 Teardown, Removing the back of the casing: 6 단계, 이미지 1/3 Xbox 360 Teardown, Removing the back of the casing: 6 단계, 이미지 2/3 Xbox 360 Teardown, Removing the back of the casing: 6 단계, 이미지 3/3
    • You must push in these buttons (7 in total)
    • It is nearly impossible to not mess up the plastic using a screwdriver, i would recommend using an x-acto knife
    • This was one of the harder steps, you must push the button in until it clicks and then go farther still
    • Make sure you keep pressure applied outwards so that the locks do not re-engage
  7. Xbox 360 Teardown, Removing the disc drive button: 7 단계, 이미지 1/3 Xbox 360 Teardown, Removing the disc drive button: 7 단계, 이미지 2/3 Xbox 360 Teardown, Removing the disc drive button: 7 단계, 이미지 3/3
    • To pop off this button, use the flat end of a spudger or flat-head screwdriver.
  8. Xbox 360 Teardown, Opening up to the motherboard: 8 단계, 이미지 1/3 Xbox 360 Teardown, Opening up to the motherboard: 8 단계, 이미지 2/3 Xbox 360 Teardown, Opening up to the motherboard: 8 단계, 이미지 3/3
    • Remove the six silver screws
    • Flip over the whole Xbox holding both the plastic and the metal, then pull off the casing
  9. Xbox 360 Teardown, Removing the disc drive: 9 단계, 이미지 1/3 Xbox 360 Teardown, Removing the disc drive: 9 단계, 이미지 2/3 Xbox 360 Teardown, Removing the disc drive: 9 단계, 이미지 3/3
    • Carefully remove the two connectors
    • The disc drive may have some tape in the front holding it in place, simply remove this.
  10. Xbox 360 Teardown, Opening up the fans: 10 단계, 이미지 1/3 Xbox 360 Teardown, Opening up the fans: 10 단계, 이미지 2/3 Xbox 360 Teardown, Opening up the fans: 10 단계, 이미지 3/3
    • To remove the fan covering, use a flat head screw driver as shown to gently pry it off
  11. Xbox 360 Teardown, Removing the fans: 11 단계, 이미지 1/3 Xbox 360 Teardown, Removing the fans: 11 단계, 이미지 2/3 Xbox 360 Teardown, Removing the fans: 11 단계, 이미지 3/3
    • Use a small flat head screw driver to open this locking mechanism and then gently remove the fan connector
    • Use a screw driver or spludger to pry out the fan from the casing
  12. Xbox 360 Teardown, Removing the power button: 12 단계, 이미지 1/3 Xbox 360 Teardown, Removing the power button: 12 단계, 이미지 2/3 Xbox 360 Teardown, Removing the power button: 12 단계, 이미지 3/3
    • To remove the "On" button simply disconnect the plastic clip
    • Remove the three black screws and pull the chip directly outwards so you do not damage the connector
  13. Xbox 360 Teardown, Removing the mother board: 13 단계, 이미지 1/2 Xbox 360 Teardown, Removing the mother board: 13 단계, 이미지 2/2
    • Remove the 9 gold screws
    • Remove the 8 black screws
    • Carefully pull out the mother board and make sure that you do not damage any connectors
  14. Xbox 360 Teardown, Displaying the main components.: 14 단계, 이미지 1/2 Xbox 360 Teardown, Displaying the main components.: 14 단계, 이미지 2/2
    • Memory card ports
    • Custom ATi Graphics Processor with 10Mb of Ram
    • 3 IBM PowerPC Cores Each Running At 3.2Ghz with 512Mb of System Ram
    • Hard drive port
    • Power port
    • HDMI and Video ports
  15. Xbox 360 Teardown, You’re finished!: 15 단계, 이미지 1/1
    • This is it. Follow these steps in reverse to re-assemble your Xbox 360 system!
Michael
회원 가입일: 10/23/16
510 평판
안내서 1개 작성함
댓글 11개
Please comment if you have any suggestions or help so that I can be sure to update this, or do a better job in the future.
Michael - 답글
Your method is very offensive and not recommended when you wont damage the case of your Xbox 360.
TheSupport - 답글
Up yours it obviously helped 3.1 thousand people. Being as you have zero guides and close to no reputation, maybe you should try it. But your input is valued, so thank you.
Michael -
$@$*-hot reply - like it!!!
lawsewilliams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 88
30일 전: 376
전체 시간: 27,870
