필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Here you would usually have a hard drive, my xbox does not. To remove it you push down the button and lift it out
You can put a flat head screw driver in between the plastic as shown and gently pry open the front
You can alternatively grab inside the USB port and pull the cover off
Use a small tool to stick in and push these pins
Be sure to keep pressure pulling outwards for this to come out easily
Make sure that you pop out the pins on both sides
Same as the bottom plate you want to push in the buttons holding this in
You have to evenly disconnect all four of these connectors holding it together
You must push in these buttons (7 in total)
Make sure you keep pressure applied outwards so that the locks do not re-engage
To pop off this button, use the flat end of a spudger or flat-head screwdriver.
Remove the six silver screws
Flip over the whole Xbox holding both the plastic and the metal, then pull off the casing
To remove the fan covering, use a flat head screw driver as shown to gently pry it off
Use a small flat head screw driver to open this locking mechanism and then gently remove the fan connector
Use a screw driver or spludger to pry out the fan from the casing
To remove the "On" button simply disconnect the plastic clip
Remove the three black screws and pull the chip directly outwards so you do not damage the connector
Remove the 9 gold screws
Remove the 8 black screws
Carefully pull out the mother board and make sure that you do not damage any connectors
Memory card ports
Custom ATi Graphics Processor with 10Mb of Ram
3 IBM PowerPC Cores Each Running At 3.2Ghz with 512Mb of System Ram
Hard drive port
Power port
HDMI and Video ports
This is it. Follow these steps in reverse to re-assemble your Xbox 360 system!
댓글 11개
Your method is very offensive and not recommended when you wont damage the case of your Xbox 360.
TheSupport - 답글
Up yours it obviously helped 3.1 thousand people. Being as you have zero guides and close to no reputation, maybe you should try it. But your input is valued, so thank you.
Michael -
$@$*-hot reply - like it!!!
this was helpful
