이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Your controller analog stick may undergo wear and tear over time. You will notice movement on the screen with no user input, such as your character's position or aim steadily changing. Use this guide to replace your analog sensor and prevent unwanted movement.
필요한 것
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
Push the trigger arm downward.
Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
Using the previously described technique, pry the housing on the right edge away from the trigger.
Rotate the trigger away from the logic board, past its housing.
Optional: It is easier to remove both, so as to avoid burning or melting the plastic while working.
다른 한 분이 해당 안내서를 완성하였습니다.
