주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Controller Analog Stick Covers Replacement
필요한 것
  1. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Battery: 1 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Battery: 1 단계, 이미지 2/2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Rear Case: 2 단계, 이미지 1/1
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 3 단계, 이미지 1/1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  4. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 5 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 5 단계, 이미지 2/2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  5. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 6 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 6 단계, 이미지 2/2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  6. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Vibration Motors: 7 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Vibration Motors: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  7. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 8 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 8 단계, 이미지 2/2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  8. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Logic Board: 9 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Logic Board: 9 단계, 이미지 2/2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  9. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Analog Stick Covers: 10 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Analog Stick Covers: 10 단계, 이미지 2/2
    • Grasp the right analog stick and pull the cover off its mount peg.
  10. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 11 단계, 이미지 1/2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 11 단계, 이미지 2/2
    • Remove the left analog stick cover using the same procedure previously described.
결론
다른 93명이 해당 안내서를 완성하였습니다.
Brett Hartt
회원 가입일: 04/12/10
126,976 평판
안내서 143개 작성하였습니다
iFixit iFixit 회원
Community
136 회원들
안내서 15,122개 작성하였습니다
댓글 3개
unnecessary steps.
3 steps:
remove all 7 screws.
flip upside down remove top plate
pull stick caps off
reinstall in reverse.
you may have to slide the vibration motors into the slots on the top half when putting back together.
zachharrizusnavy - 답글
Hola buenas tardes feliz domingo. Es tan amable de contactarme co algún proveedor de respuestos para mando de la xbox 360. Como circuitos integrados gatillos chips de vinculación entre otros. Selo agradecería
Jose - 답글
For the wired controller, the steps are the same, and you still have to lift a sticker on the back to get to that 7th screw. But the screws are Philips, not Torx.
Fristle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 33
30일 전: 209
전체 시간: 100,464
