소개
Steady your aim by replacing the analog stick grips on the Xbox 360 wireless controller.
필요한 것
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Insert a Spudger between the front and rear cases along the left edge of the controller.
Rotate the spudger toward the front of the controller, prying the two cases apart.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
다른 93명이 해당 안내서를 완성하였습니다.
댓글 3개
unnecessary steps.
3 steps:
remove all 7 screws.
flip upside down remove top plate
pull stick caps off
reinstall in reverse.
you may have to slide the vibration motors into the slots on the top half when putting back together.
