주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Controller Logic Board Replacement
필요한 것
  1. Xbox 360 Wireless Controller Logic Board Replacement, Battery: 1 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement, Battery: 1 단계, 이미지 2/2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Logic Board Replacement, Rear Case: 2 단계, 이미지 1/1
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Logic Board Replacement: 3 단계, 이미지 1/1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  4. Xbox 360 Wireless Controller Logic Board Replacement: 5 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement: 5 단계, 이미지 2/2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  5. Xbox 360 Wireless Controller Logic Board Replacement: 6 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement: 6 단계, 이미지 2/2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  6. Xbox 360 Wireless Controller Logic Board Replacement, Vibration Motors: 7 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement, Vibration Motors: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  7. Xbox 360 Wireless Controller Logic Board Replacement: 8 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement: 8 단계, 이미지 2/2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  8. Xbox 360 Wireless Controller Logic Board Replacement, Logic Board: 9 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement, Logic Board: 9 단계, 이미지 2/2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  9. Xbox 360 Wireless Controller Logic Board Replacement, Analog Stick Covers: 10 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement, Analog Stick Covers: 10 단계, 이미지 2/2
    • Grasp the right analog stick and pull the cover off its mount peg.
  10. Xbox 360 Wireless Controller Logic Board Replacement: 11 단계, 이미지 1/2 Xbox 360 Wireless Controller Logic Board Replacement: 11 단계, 이미지 2/2
    • Remove the left analog stick cover using the same procedure previously described.
  11. Xbox 360 Wireless Controller Logic Board Replacement, Triggers: 12 단계, 이미지 1/3 Xbox 360 Wireless Controller Logic Board Replacement, Triggers: 12 단계, 이미지 2/3 Xbox 360 Wireless Controller Logic Board Replacement, Triggers: 12 단계, 이미지 3/3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  12. Xbox 360 Wireless Controller Logic Board Replacement: 13 단계, 이미지 1/3 Xbox 360 Wireless Controller Logic Board Replacement: 13 단계, 이미지 2/3 Xbox 360 Wireless Controller Logic Board Replacement: 13 단계, 이미지 3/3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  13. Xbox 360 Wireless Controller Logic Board Replacement: 14 단계, 이미지 1/3 Xbox 360 Wireless Controller Logic Board Replacement: 14 단계, 이미지 2/3 Xbox 360 Wireless Controller Logic Board Replacement: 14 단계, 이미지 3/3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  14. Xbox 360 Wireless Controller Logic Board Replacement: 15 단계, 이미지 1/3 Xbox 360 Wireless Controller Logic Board Replacement: 15 단계, 이미지 2/3 Xbox 360 Wireless Controller Logic Board Replacement: 15 단계, 이미지 3/3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
결론
다른 40명이 해당 안내서를 완성하였습니다.
Brett Hartt
회원 가입일: 04/12/10
125,646 평판
안내서 143개 작성하였습니다
iFixit iFixit 회원
Community
139 회원들
안내서 16,820개 작성하였습니다
4 Comments
Does it matter which side the motors are returned to? I think I may have swapped positions with my two motors.
brian - 답글
Any guides for troubleshooting the test points on the board as to determine why the left trigger doesn't aim during gameplay? I've replaced the potentiometer with a brand new one but still nothing, everything else works perfectly …thoughts?
BURNHOT ROBINSON - 답글
I don't need a removal guide I need a diagram that shows me how to put the trigger on a button on top so a child with deformed fingers can use it. The triggers apparently have hall type sensors.
jim27601 - 답글
The logic board won't come out, and I don't want to force it out. Any ideas on how to take it out?
Xander Uchida - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 48
30일 전: 209
전체 시간: 60,273
