주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Controller Triggers Replacement
필요한 것
  1. Xbox 360 Wireless Controller Triggers Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Triggers Replacement, Rear Case: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Triggers Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Triggers Replacement: 4 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Triggers Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Triggers Replacement: 6 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 6 단계, 이미지 2개 중 2개
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: 7 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Triggers Replacement: 8 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Triggers Replacement, Logic Board: 9 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Triggers Replacement, Logic Board: 9 단계, 이미지 2개 중 2개
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Triggers Replacement, Triggers: 10 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller Triggers Replacement, Triggers: 10 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller Triggers Replacement, Triggers: 10 단계, 이미지 3개 중 3개
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller Triggers Replacement: 11 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 11 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller Triggers Replacement: 11 단계, 이미지 3개 중 3개
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller Triggers Replacement: 12 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 12 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller Triggers Replacement: 12 단계, 이미지 3개 중 3개
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller Triggers Replacement: 13 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller Triggers Replacement: 13 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller Triggers Replacement: 13 단계, 이미지 3개 중 3개
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
결론
다른 46명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,238 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,644개를 작성함
5가이드 댓글
use a small tag of double sided tape to hold the counterweights in when you rebuild or its nearly impossible to tip up the two halfs of the controller to fit them together. With the counterweight just slightly stuck into place with a tiny tag of double sided tape you can tip that half of the controller upside down to fit on top of the other half. Still awkward but do-able. Almost impossible otherwise.
iorigrif - 답글
If i leave out the vibrations things will it cause the problems tonthe board ??
Michael Francis - 답글
These instructions were given in proper order and understanding
Arthur Murray Doan - 답글
IMO this could have benefited from some instructions on how to get the triggers back on, cause it was quite a challenge.
The way I managed to do it, is you've got to reverse both step 11 and step 10 in one go, otherwise it would be impossible to get the trigger peg into the white arm (at least I couldn't figure out a way to do it): before reversing step 11, hold the white arm up and to same side you pushed it in the step 10, and then once you click it back into place, the peg would also go into the slot in the arm. For me it was easier to do for LT than RT - the latter too a few tries, so I would recommend doing LT first and then RT.
Rathori - 답글
Left trigger on xbox 360 wireless controler not working
Rog - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 127
지난 30일: 408
전체 시간: 88,506
