주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xbox 360 Wireless Controller 수리는 자사의 서비스 설명서를 사용하세요.
  1. Xbox 360 Wireless Controller, Introduction: 1 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller, Introduction: 1 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller, Introduction: 1 단계, 이미지 3개 중 3개
    • This is the Xbox 360 wireless controller we are going to work with
  2. Xbox 360 Wireless Controller, Took out all the screws and torn apart: 2 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller, Took out all the screws and torn apart: 2 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller, Took out all the screws and torn apart: 2 단계, 이미지 3개 중 3개
    • I unscrewed the screws with a special screwdriver called Torx 8 T8 screwdriver.
  3. Xbox 360 Wireless Controller, I found a thing that’s looks like a motor: 3 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller, I found a thing that’s looks like a motor: 3 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller, I found a thing that’s looks like a motor: 3 단계, 이미지 3개 중 3개
    • I was looking at the different parts and I found two vibration rumble motors that make the controller vibrate. For example if you play call of duty and you shoot a gun the controller will vibrate.
  4. Xbox 360 Wireless Controller, I look at the backside of the controller: 4 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller, I look at the backside of the controller: 4 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller, I look at the backside of the controller: 4 단계, 이미지 3개 중 3개
    • I figured out how to open the other side found three things. I didn't know what they were and I found out they were the triggers for the controller. I also found out how the batteries connect to the controller. Finally, I found out that they where motors connect and I found out. I I also notice the processor chip was the same as a calculator.
작성자
2다른 기여자 명과 함께
Jose fierros
회원 가입일: 04/26/19
119 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 32
지난 30일: 144
전체 시간: 2,398
