소개
Are your A, B, X, Y buttons busted or not working from an epic game and or rage? Have they lost sensitivity over time? Don't get upset, they can be replaced! This guide will show you how to open the controller and replace the colored A, B, X, Y buttons.
필요한 것
Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
Pull the two AA batteries out.
Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
Use a T6 Torx screwdriver to remove the 1.5mm screw.
Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
Start with one side of the controller (left or right).
Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
Pull the front and back panels apart to separate them and expose the inside of the controller.
Lift the battery compartment out of the controller and set it outside of the controller.
Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
Use precision tweezers to remove the red and black wires that are attached to the circuit board.
Use a T6 Torx screwdriver to remove the four 2.3mm screws.
Lift up the black locking tab on the ZIF connector to release the ribbon cable.
Remove the silicon pad on the left side to expose the A, B, X, Y buttons.
Flip over the controller to remove the buttons from their sockets.
