주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Speed Wheel Back Panel Replacement
필요한 것
  1. Xbox 360 Wireless Speed Wheel Back Panel Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xbox 360 Wireless Speed Wheel Back Panel Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
    • Pull the two AA batteries out.
  2. Xbox 360 Wireless Speed Wheel Back Panel Replacement, Back Panel: 2 단계, 이미지 2개 중 1개 Xbox 360 Wireless Speed Wheel Back Panel Replacement, Back Panel: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
    • Use a T6 Torx screwdriver to remove the 1.5mm screw.
  3. Xbox 360 Wireless Speed Wheel Back Panel Replacement: 3 단계, 이미지 3개 중 1개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 3 단계, 이미지 3개 중 2개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a spudger and pry at these three locations to detach the middle cover.
    • Pull off the middle piece cover to reveal three screws.
    • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Remove the cover.
  4. Xbox 360 Wireless Speed Wheel Back Panel Replacement: 4 단계, 이미지 3개 중 1개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 4 단계, 이미지 3개 중 2개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 90mm screws with a T8 Torx screwdriver.
    • Lift up the silver middle piece to remove.
  5. Xbox 360 Wireless Speed Wheel Back Panel Replacement: 5 단계, 이미지 3개 중 1개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 5 단계, 이미지 3개 중 2개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to remove the silver prong.
    • With the spudger, pinch the metal spring and slowly pull up to remove.
    • Use the spudger to remove eject button.
    • Remove the screw holding in the eject button with a T8 Torx screwdriver.
  6. Xbox 360 Wireless Speed Wheel Back Panel Replacement: 6 단계, 이미지 3개 중 1개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 6 단계, 이미지 3개 중 2개 Xbox 360 Wireless Speed Wheel Back Panel Replacement: 6 단계, 이미지 3개 중 3개
    • This step is very difficult and may require a third hand.
    • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
    • Start with one side of the controller (left or right).
    • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
    • The white circular caps at the top of the controller will pop off by applying light force.
    • Pull the front and back panels apart to separate them and expose the inside of the controller.
결론
작성자
5다른 기여자 명과 함께
lauren paganella
회원 가입일: 02/15/18
464 평판
안내서 4개를 작성함
USF Tampa, Team S16-G5, Boczar Spring 2018 USF Tampa, Team S16-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G5
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 18
전체 시간: 1,271
