주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Speed Wheel Battery Compartment Replacement
필요한 것
  1. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Battery: 1 단계, 이미지 1/2 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
    • Pull the two AA batteries out.
  2. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Back Panel: 2 단계, 이미지 1/2 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Back Panel: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
    • Use a T6 Torx screwdriver to remove the 1.5mm screw.
  3. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 3 단계, 이미지 1/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 3 단계, 이미지 2/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 3 단계, 이미지 3/3
    • Insert a spudger and pry at these three locations to detach the middle cover.
    • Pull off the middle piece cover to reveal three screws.
    • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Remove the cover.
  4. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 4 단계, 이미지 1/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 4 단계, 이미지 2/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 4 단계, 이미지 3/3
    • Remove the two 90mm screws with a T8 Torx screwdriver.
    • Lift up the silver middle piece to remove.
  5. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 5 단계, 이미지 1/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 5 단계, 이미지 2/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 5 단계, 이미지 3/3
    • Use a spudger to remove the silver prong.
    • With the spudger, pinch the metal spring and slowly pull up to remove.
    • Use the spudger to remove eject button.
    • Remove the screw holding in the eject button with a T8 Torx screwdriver.
  6. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 6 단계, 이미지 1/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 6 단계, 이미지 2/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement: 6 단계, 이미지 3/3
    • This step is very difficult and may require a third hand.
    • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
    • Start with one side of the controller (left or right).
    • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
    • The white circular caps at the top of the controller will pop off by applying light force.
    • Pull the front and back panels apart to separate them and expose the inside of the controller.
  7. Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Battery Compartment: 7 단계, 이미지 1/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Battery Compartment: 7 단계, 이미지 2/3 Xbox 360 Wireless Speed Wheel Battery Compartment Replacement, Battery Compartment: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift the battery compartment out of the controller and set it outside of the controller.
    • Do not yank, stress, or pull on the wires for removal.
    • Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
결론
lauren paganella
회원 가입일: 02/15/18
429 평판
안내서 4개 작성하였습니다
USF Tampa, Team S16-G5, Boczar Spring 2018 USF Tampa, Team S16-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G5
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 28
전체 시간: 2,318
