소개
This is the teardown for the original Microsoft Xbox, not the Xbox 360.
필요한 것
동영상 개요
Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
Or use an exacto knife to cut circles out where the two screws are located. First make indentations over the screws with your finger, this to help make it easier to trace the holes before cutting. The end result is often better than trying to peel corners. You can also try removing the stickers using a hair dryer, but it's not easy; if successful, they can potentially be reapplied, however.
Unplug both the ribbon cable and power cable from hard drive.
Remove the disk drive. It should come right out.
Unplug the ribbon cable and yellow cables from back of disk drive.
Congratulations, your Xbox is now completely dismembered.
My Xbox is not completely disassembled. How do I get the front panel and metal shield out of the bottom case so I can wash them?
Same here. I got everything out but the front. Trying to replace the power/eject button
You forgot the power button area....
다른 48명이 해당 안내서를 완성하였습니다.
댓글 10개
Awesomeness, thanks a lot!
godoyander - 답글
Thanks a million - perfect!
Heatsink removal?
Face plate removal?
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
would you be able to make a guide on how to remove the plastic outer shell from the metal parts inside? i want to clean a dirty shell but i don't know how to get the parts seperated.
Looks like I'm not skilled at fixing things, my machine broke right after that.
It was really challenging. Drive Mad
Parfait, merci ;-)
Attractive information. I can fix the Xbox. Your steps are excellent. Have a nice day, bro!
