이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
동영상 개요
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the Xbox on its back and remove the rubber feet in each corner using a flathead screwdriver.
Peel off the stickers on the bottom side of the Xbox and unscrew all six screws using a Torx 20 screwdriver bit. Set the screws off to the side so you don't misplace them.
In order to remove the IDE cable, pull firmly on the cable straight back from the hard drive.
Remove the screw from underneath the IDE cable using a Torx 10 screwdriver.
Remove the cable the same way that the hard drive cable was removed. Simply pull the cable straight out from the DVD drive.
Remove the screws from each end of the DVD drive using a Torx 10 screwdriver.
Once both screws have been removed pull straight upwards to remove the drive.
Unscrew all eleven screws that hold the mother board in place. Use a Torx 10 screwdriver to unscrew them.
Remove the power cord by gently lifting it out at a 45 degree angle.
After the power cord is removed gently lift out the mother board by placing your fingers around the edges inside the case and lifting straight up and out.
Remove the old fan by pressing gently on the clips on each side with a flathead screwdriver and then carefully clip in a new fan.
다른 한 분이 해당 안내서를 완성하였습니다.
