주요 콘텐츠로 건너뛰기
Xbox Hard Drive Management
필요한 것
  1. Xbox Hard Drive Management, Xbox Hard Drive Management: 1 단계, 이미지 1/1
    • Boot up your Xbox without a disc in the drive and you will get the dashboard. Head to "Memory", as the Xbox doesn't have a single format HD option.
  2. Xbox Hard Drive Management: 2 단계, 이미지 1/1
    • Here you can see the Xbox hard drive options. Select the save you want to delete, and hit A.
  3. Xbox Hard Drive Management: 3 단계, 이미지 1/1
    • Press A to delete the save. Then go back and delete all the other saves you want to delete. Now your Xbox HD is completely clear of savegames.
    • If you're selling your Xbox, go to Settings and turn off auto-login and go to Xbox LIVE and remove your account options.
결론
Make sure you haven't left any music on your Xbox HD if you're selling your Xbox.
다른 20명이 해당 안내서를 완성하였습니다.
Eddie Meehan
회원 가입일: 09/23/13
894 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 13
30일 전: 58
전체 시간: 11,178
