소개
This is the replacement guide for the motherboard in the Microsoft Xbox.
  1. Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
  2. Turn the Xbox over to reveal the four rubber feet.
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
    The screw is in the outside corner. If you pry up only the half of the foot on that side, you can easily remove the (very long) screw, and the foot will stay attached.
    Ian Butler - 답글
  3. There are 2 more screws hidden under the two labels on the bottom of the case. You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    It is also easy to feel for the screw hole with your finger and then cut a hole, or punch it out with the tip of the Torx driver to reveal the screw.
    Ian Butler - 답글
  4. Remove the six T20 Torx screws securing the top cover to the bottom cover.
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
  5. Wedge a metal spudger and carefully pry upwards to slightly separate the top and bottom covers. Flip the Xbox right side up.
    • Wedge a metal spudger and carefully pry upwards to slightly separate the top and bottom covers.
    • Flip the Xbox right side up.
    • Hold the sides and lift the Xbox slightly off the bench. A gentle shake of the unit should see the top cover separate from the rest of the unit quite easily.
    • Placing the Xbox on your lap while separating the top and bottom covers may make the process easier.
  6. Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover. Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
  7. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  8. Remove the three 3 mm T10 screws securing the hard drive to the Xbox. There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up.  The other two are at the front right and left sides of the hard drive.
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  9. Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out. Lift the plastic hard drive carrier out of the Xbox case.
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
  10. Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side). Carefully remove the hard drive from the plastic carrier.  Gentle rocking will see the hard drive come out quite easily. Carefully remove the hard drive from the plastic carrier.  Gentle rocking will see the hard drive come out quite easily.
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
  11. Pull both the hard drive data  ribbon cable and the power cable straight up from the hard drive. They may be firmly seated, so be careful trying to remove them.  DO NOT pull the wires as you may damage the cable assembly.
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
    Remember that the new drive will only work if it has been properly prepared, and the Xbox has been modified.
    Ian Butler - 답글
  12. Remove the disk drive. It should come right out. Unplug the ribbon cable and yellow cables from back of disk drive. Unplug the ribbon cable and yellow cables from back of disk drive.
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
    I dont got the tools and i dont know how to do ut
    jacob lowery - 답글
  13. Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • ONLY REMOVE IF DEAD!
    It is ok to remove the drive if it isn't dead. If repairs are required to the drive it needs to be removed from the drive's housing.
    Navy Vet 2015 - 답글
  14. Unplug the multi-colored power cord from the motherboard. It is in there pretty tightly, so it may take some effort.
    • Unplug the multi-colored power cord from the motherboard. It is in there pretty tightly, so it may take some effort.
  15. Using T10 Torx screwdriver, remove two 3mm screws from the tan power supply board. Using T10 Torx screwdriver, remove two 3mm screws from the tan power supply board.
    • Using T10 Torx screwdriver, remove two 3mm screws from the tan power supply board.
  16. Remove the power supply and set it aside. It should lift right out.
    • Remove the power supply and set it aside. It should lift right out.
    • Be very careful not to touch the copper coil or capacitors on the power supply. They may shock you.
  17. Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard. Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  18. Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven. Unplug the power cable attached to the fan.
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  19. Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
결론
다른 28명이 해당 안내서를 완성하였습니다.
rmarstel
회원 가입일: 2009년 10월 29일
3,868 평판
안내서 5개 작성하였습니다
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009 회원
CPSU-MANESS-F09S18G2
3 회원들
안내서 10개 작성하였습니다
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
Navy Vet 2015 - 답글
What about the key lock between the HDD and original motherboard? Wouldn't you get an error message installing a new motherboard?
chris - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 32
지난 30일: 566
전체 시간: 33,626
