주요 콘텐츠로 건너뛰기
Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement
필요한 것
  1. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement, Controller Button and Trigger: 1 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement, Controller Button and Trigger: 1 단계, 이미지 2개 중 2개
    • Remove the seven screws from the back of the controller using a Phillips #1 screwdriver.
  2. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 2 단계, 이미지 3개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 2 단계, 이미지 3개 중 2개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 2 단계, 이미지 3개 중 3개
    • Place an opening tool between the front and rear controller panels at the bottom of the controller.
    • Pry the bottom of the controller open around the audio port.
    • The controller might make a loud click; that is okay.
  3. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 3 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 3 단계, 이미지 2개 중 2개
    • Remove both screws on the back of the motherboard under the triggers using a Phillips #1 screwdriver.
  4. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 4 단계, 이미지 3개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 4 단계, 이미지 3개 중 2개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 4 단계, 이미지 3개 중 3개
    • Place your left hand at the base of the motherboard and your right hand on the frame.
    • Lift the motherboard up from the pegs that hold it in place.
    • The motherboard will still be connected to the controller once off the pegs.
    • Do not try to force the motherboard out after getting it off the pegs.
    • Pull down gently to remove the motherboard.
  5. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 5 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 5 단계, 이미지 2개 중 2개
    • Under each trigger is a small guard rail that needs to be pushed in order to get to the screws for the trigger.
    • Push the rail towards the motherboard to free the triggers to get to the screws.
  6. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two screws from each of the triggers (four total) using a Phillips #1 screwdriver.
    • The triggers will fall out when unscrewed.
  7. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 7 단계, 이미지 3개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 7 단계, 이미지 3개 중 2개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 7 단계, 이미지 3개 중 3개
    • Replace each of the triggers by screwing them back together.
    • Push the rail back onto the trigger peg.
    • The motherboard is done until reassembly.
  8. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 8 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two screws from the top bumper board using a Phillips #1 screwdriver.
  9. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 9 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 9 단계, 이미지 2개 중 2개
    • Pull up on the bumper board to remove it.
  10. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 10 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 10 단계, 이미지 2개 중 2개
    • Pick up the circuit board to remove it from the base.
    • The circuit board is loose and might fall out in Step 9.
  11. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 11 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the rubber button cover.
  12. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 12 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the inner buttons.
  13. Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 13 단계, 이미지 2개 중 1개 Xbox One Afterglow Prismatic Wired Controller Button and Trigger Replacement: 13 단계, 이미지 2개 중 2개
    • Replace each of the buttons.
    • Each of the buttons have pegs that will help you line them up in the correct location and orientation.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zachary Marcotte
회원 가입일: 09/28/21
371 평판
안내서 1개를 작성함
6가이드 댓글
Can you tell me where i can get the exact same circuit board for this controller i would greatly appreciate it if you respond!
ismaeel - 답글
Just look on ebay broken electronic's and you can fine several of these I have several controllers on ebay for 5 dollars each myself (they all work)
Zachary Marcotte -
I took my controller apart up to step 4 in order to reseat the analog stick sensors to help with stick drift and this guide helped me check my work to make sure I hadn't missed anything and was doing it properly. The pictures were quite handy.
I think it would be good to add that there's a pin array attached to the second circuit board with the bumpers that you need to re socket when putting the controller back together. The controller mostly works even without the pins in place, but the Y button is connected to one of these pins and will not work unless the pins are properly socketed, I had to disassemble and reassemble my controller a second time after realising this, but once I got it done with the pins in the right place it worked as desired. It's entirely possible and maybe even likely you'll bend the pins on the secondary board during initial disassembly (I had), but it's easy to simply set them back upright, just don't lose the pin guide!
Jay Denney - 답글
We didn't really have that problem, it is good to know though. We did this project as a technical level writing class so we won't be doing any updates. I am glad it helped you.
Zachary Marcotte -
Where can I get a replacement rubber button cover? My 'A' button is getting stuck down because the rubber cap is worn out.
Alec Heasley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 59
지난 30일: 305
전체 시간: 7,107
