주요 콘텐츠로 건너뛰기
Xbox One Elite Controller Series 2 Left Joystick Replacement
필요한 것
동영상 지침
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
@HectorNavarroMX
회원 가입일: 06/25/18
4,405 평판
안내서 26개를 작성함
13가이드 댓글
Does this work for the series 1 elite controller also?
Nicola - 답글
Can we please get some insight to what the silver tape that is put over certain leads?
- What is the silver tape?
- What is the silver tape used for?
- Which leads are the silver tape covering?
- What happens if silver tape is not used?
Noah Adams - 답글
It is called Kapton Tape. It is used to protect components from heat during the rework process. If you don't use it, there is a chance of damaging the components. Even though the damage may not be seen by the naked eye. Hope this helps!
Ken Stopczynski -
It is aluminum tape not kapton tape. It is covering a surface mount component mounted within the area of the pins you have to desolder to remove the analog stick. He is covering it up to protect it from the heat and also to keep it from desoldering and moving while replacing the analog stick.
Damon Rowan -
ma per caso accetti spedizioni, perché anche a me mi si è rotto così
Gabriel Pisciotta - 답글
댓글 쓰기
조회 통계:
지난 24시간: 69
지난 7일: 260
지난 30일: 1,125
전체 시간: 56,101
