주요 콘텐츠로 건너뛰기
Xbox One Kinect LED Sensor Replacement
필요한 것
  1. Xbox One Kinect LED Sensor Replacement, Outer Shell: 1 단계, 이미지 1/1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect LED Sensor Replacement: 2 단계, 이미지 1/3 Xbox One Kinect LED Sensor Replacement: 2 단계, 이미지 2/3 Xbox One Kinect LED Sensor Replacement: 2 단계, 이미지 3/3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect LED Sensor Replacement: 3 단계, 이미지 1/3 Xbox One Kinect LED Sensor Replacement: 3 단계, 이미지 2/3 Xbox One Kinect LED Sensor Replacement: 3 단계, 이미지 3/3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  4. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: 4 단계, 이미지 1/3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: 4 단계, 이미지 2/3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: 4 단계, 이미지 3/3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
결론
Malak Anshassi
회원 가입일: 09/22/14
329 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,144
