주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Kinect Microphone Replacement
필요한 것
  1. Xbox One Kinect Microphone Replacement, Outer Shell: 1 단계, 이미지 1개 중 1개
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    댓글 쓰기
  2. Xbox One Kinect Microphone Replacement: 2 단계, 이미지 3개 중 1개 Xbox One Kinect Microphone Replacement: 2 단계, 이미지 3개 중 2개 Xbox One Kinect Microphone Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    댓글 쓰기
  3. Xbox One Kinect Microphone Replacement: 3 단계, 이미지 3개 중 1개 Xbox One Kinect Microphone Replacement: 3 단계, 이미지 3개 중 2개 Xbox One Kinect Microphone Replacement: 3 단계, 이미지 3개 중 3개
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    댓글 쓰기
  4. Xbox One Kinect Microphone Replacement, Microphone: 4 단계, 이미지 3개 중 1개 Xbox One Kinect Microphone Replacement, Microphone: 4 단계, 이미지 3개 중 2개 Xbox One Kinect Microphone Replacement, Microphone: 4 단계, 이미지 3개 중 3개
    • Disconnect the cable connecting the infrared sensor to the motherboard.
    • Remove the one 3.1x7.7 mm T9 screw from the infrared sensor.
    • Remove the infrared sensor board for the Kinect.
    댓글 쓰기
  5. Xbox One Kinect Microphone Replacement: 5 단계, 이미지 3개 중 1개 Xbox One Kinect Microphone Replacement: 5 단계, 이미지 3개 중 2개 Xbox One Kinect Microphone Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the white ribbon cable from the motherboard using tweezers.
    • Remove the four 3.1x7.7 mm T9 screws holding the stand containing the microphone in place.
    • Unstick the black bracket holding the ribbon cable with a spudger, and remove the stand from the body of the Kinect.
    • Replace with a working stand from a different Xbox One Kinect.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Charles Schoonover
회원 가입일: 09/22/14
215 평판
안내서 2개를 작성함
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G3
4 회원들
안내서 7개를 작성함
1가이드 댓글
I love this guide, guys. Even having never seen an XBOX Kinect, I have a very clear image of how to approach this repair/ replacement. Your markup is great and clear, your action shots denote direction where it's needed, and your pictures show individual components in a way that leaves no confusion. Your steps are adequately descriptive as well. If I have to critique one thing, is it necessary to denote the bit type used on the driver when removing screws? I'm not sure if it is, but my group included this information. All in all, you did a great job with this one. Your guides are knowledgeable and concise.
Noah Hickerson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 70
전체 시간: 3,063
