주요 콘텐츠로 건너뛰기
Xbox One Kinect Outer Shell Replacement
필요한 것
  1. Xbox One Kinect Outer Shell Replacement, Outer Shell: 1 단계, 이미지 1개 중 1개
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect Outer Shell Replacement: 2 단계, 이미지 3개 중 1개 Xbox One Kinect Outer Shell Replacement: 2 단계, 이미지 3개 중 2개 Xbox One Kinect Outer Shell Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect Outer Shell Replacement: 3 단계, 이미지 3개 중 1개 Xbox One Kinect Outer Shell Replacement: 3 단계, 이미지 3개 중 2개 Xbox One Kinect Outer Shell Replacement: 3 단계, 이미지 3개 중 3개
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
결론
작성자
4다른 기여자 명과 함께
Charles Schoonover
회원 가입일: 09/22/14
215 평판
안내서 2개를 작성함
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G3
4 회원들
안내서 7개를 작성함
1가이드 댓글
Again, another great guide, guys. Also, this is a solid prerequisite. I noticed when reviewing this one that you did a good job of indicating which tools to use and when. Your markup is clear and concise, and your writing is not overly technical and complicated. Your photos and action steps are also very clear. You did a great job this semester!
P.S. -- I'm not sure if we're actually supposed to post our reviews as comments here. You may not want them on your guides! If I'm mistaken here, don't hesitate to remove them. I'm submitting through Canvas as well.
Noah Hickerson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 25
전체 시간: 2,639
