주요 콘텐츠로 건너뛰기
Xbox One Play & Charge Kit not charging with USB?
필요한 것
  1. Xbox One Play & Charge Kit not charging with USB?, Xbox One Play & Charge Kit not charging with USB?: 1 단계, 이미지 1/1
    • Xbox One - Play and Charge Kit Not charging while connected to USB
  2. Xbox One Play & Charge Kit not charging with USB?: 2 단계, 이미지 1/2 Xbox One Play & Charge Kit not charging with USB?: 2 단계, 이미지 2/2
    • Pull off the battery cover. and remove the battery.
    • Reconnect the USB and make sure the controller powers on. IF it does this fix WILL WORK.
  3. Xbox One Play & Charge Kit not charging with USB?: 3 단계, 이미지 1/3 Xbox One Play & Charge Kit not charging with USB?: 3 단계, 이미지 2/3 Xbox One Play & Charge Kit not charging with USB?: 3 단계, 이미지 3/3
    • Take a small piece of the Low-Density Foam Weatherstrip Tape and place it, sticky side down, in the center of the controller.
    • Replace the battery.
    • Reconnect the USB and GENTLY press the battery into the controller while the USB is connected. This will allow you to see if the fix worked. NOTE- it takes a second or so for the light on the USB cable to come on after the controller powers on.
  4. Xbox One Play & Charge Kit not charging with USB?: 4 단계, 이미지 1/1
    • If all went well, you can replace the battery cover. Take care though as it will be much harder to get it back on. Don't worry, those little clips are much thougher than you think. Just take your time and be carefull. If it don't fit- don't force it, try trimming the tape instead.
결론
That’s it. You can now charge your controller like it was intended. At least we are not going to have to give more money to MS to get this fixed.
다른 25명이 해당 안내서를 완성하였습니다.
bbhsascha
회원 가입일: 05/14/16
915 평판
안내서 1개 작성함
댓글 35개
Let me know if you have any issues or any suggestions on how to make this guide better. I ran into this issue and as normal MS was less than useless. I ended up replacing the controller, the USB cable and the battery in hopes that something will fix it.
bbhsascha - 답글
Thanks mate, squeezed on the battery (in towards the controller) as I inserted the cable and the light appeared on the cable. Before I tried just plugging it in to no help in result of the led indicator on the cable. But this solved it, thought I had a faulty battery/controller for a sec. Saved me some bucks there, much appreciated
TknighT - 답글
Glad it worked for you. Thanks for leaving a comment. Please note though I had this issue but as it turns out it was my controller. I did end up buying a new one. But in a pinch or at 2am this will help and keep you from tossing the %#*@ thing out the window.
bbhsascha -
Doesn’t work. Tried a know working battery from my other controller (which works in that controller), to no avail. Tried another battery from another controller that it works, nothing. The problem is the controller, not my battery (which is new).
claudiojourneyman - 답글
THANKS! Did it like you told in your instruction and now the controller is charging! Thumbs up!
Ali - 답글
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 156
30일 전: 734
전체 시간: 68,645
