주요 콘텐츠로 건너뛰기
Xbox One S All Digital Edition IR Blaster Replacement
필요한 것
  1. Xbox One S All Digital Edition IR Blaster Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 1개 Xbox One S All Digital Edition IR Blaster Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 2개 Xbox One S All Digital Edition IR Blaster Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 3개
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition IR Blaster Replacement: 2 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition IR Blaster Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition IR Blaster Replacement: 3 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition IR Blaster Replacement: 3 단계, 이미지 2개 중 2개
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition IR Blaster Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition IR Blaster Replacement, IR Blaster: 5 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition IR Blaster Replacement, IR Blaster: 5 단계, 이미지 2개 중 2개
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  6. Xbox One S All Digital Edition IR Blaster Replacement: 6 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition IR Blaster Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jules Hajjar
회원 가입일: 10/10/19
1,915 평판
안내서 8개를 작성함
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 회원
CPSU-REGAN-F19S12G6
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 43
전체 시간: 2,521
