주요 콘텐츠로 건너뛰기
Xbox One S All Digital Edition Plastic Enclosure Replacement
필요한 것
  1. Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 1개 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 2개 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 3개
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Plastic Enclosure Replacement: 2 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Plastic Enclosure Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Plastic Enclosure Replacement: 3 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Plastic Enclosure Replacement: 3 단계, 이미지 2개 중 2개
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Plastic Enclosure Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the metal enclosure so that the fan cover is on top.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jules Hajjar
회원 가입일: 10/10/19
1,915 평판
안내서 8개를 작성함
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 회원
CPSU-REGAN-F19S12G6
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 111
전체 시간: 3,629
