소개
When taking the case off of the Xbox One S, take care to not damage the clips.
Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Important!!
You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
I dont mind because it's my own Xbox, but what if it belonged to a customer?
Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
Do not remove the back panel from the metal housing by popping loose the “rivets” in Step 5 photo. Those are not rivets, they are melted post-end mounts in which the heads will break off and CAN NOT BE REPLACED by the do-it-yourself repairer (unless you want to try hot gluing the mounts back to the panel, but success is uncertain with this method). While doing my own tear-down following the photo examples, I thought the rear panel was meant to come off due to the photo of it laying next to the body in Step 7. This is inaccurate, and will most likely result in a loose fitting panel upon reassembly. The “rivets” no longer have a means to hold onto the metal body tray they came loose from. So you will have the panel relying on alignment back to the channel the tabs came out of in order to hold it to the back of your machine. Other than this issue, I was able to perform the tear-down without problem.
Gently separate the interior case from the white exterior case using the appropriate method.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 3개
I struggled with the retention tabs the first time I opened the Xbox S. I dabbed a little Armor All on a Qtip and coated both sides of tabs with a little. Popped right open the second time, wiped Armor All on the fan blades as well to minimize dust collection.
Hi!
Great review of the process! I have a question, having stripped down an rebuilt an XBox One S to extract a 500 yuan note and two peties my 7 year old inserted in the CD/DVD slop, as well as a DOA DVD drive the power switch is not working. It works if I short the contact but there appears to be a square hole in the back of the power switch (the x box logo)
Should there be a conducting contact in the back of the switch and if so, is it simply a square lump of steel or is it tapered? Would like the dimensions please.
Many thanks for taking time to reply!
Dr B
Dr John C Bullas
Southampton UK
Hi can u fit a core i5 apple gen in Xbox one s case
