주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Xbox One S Case Replacement
필요한 것
  1. Xbox One S Case Replacement, Case: 1 단계, 이미지 1/1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Case Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
  3. Xbox One S Case Replacement: 3 단계, 이미지 1/1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Case Replacement: 4 단계, 이미지 1/2 Xbox One S Case Replacement: 4 단계, 이미지 2/2
    • Find all of the green screws on the metal case labeled F1 through F6.
    • Take the T10 Torx screwdriver and remove the six 50 mm long screws.
  5. Xbox One S Case Replacement: 5 단계, 이미지 1/3 Xbox One S Case Replacement: 5 단계, 이미지 2/3 Xbox One S Case Replacement: 5 단계, 이미지 3/3
    • The port cover is held in place with rivets. Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
  6. Xbox One S Case Replacement: 6 단계, 이미지 1/2 Xbox One S Case Replacement: 6 단계, 이미지 2/2
    • Gently separate the interior case from the white exterior case using the appropriate method.
결론
다른 36명이 해당 안내서를 완성하였습니다.
Christopher Chen
회원 가입일: 04/26/17
621 평판
안내서 2개 작성하였습니다
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G3
4 회원들
안내서 56개 작성하였습니다
댓글 5개
I struggled with the retention tabs the first time I opened the Xbox S. I dabbed a little Armor All on a Qtip and coated both sides of tabs with a little. Popped right open the second time, wiped Armor All on the fan blades as well to minimize dust collection.
Mike DePedro - 답글
Hi!
Great review of the process! I have a question, having stripped down an rebuilt an XBox One S to extract a 500 yuan note and two peties my 7 year old inserted in the CD/DVD slop, as well as a DOA DVD drive the power switch is not working. It works if I short the contact but there appears to be a square hole in the back of the power switch (the x box logo)
Should there be a conducting contact in the back of the switch and if so, is it simply a square lump of steel or is it tapered? Would like the dimensions please.
Many thanks for taking time to reply!
Dr B
Dr John C Bullas
Southampton UK
john.bullas - 답글
Hi can u fit a core i5 apple gen in Xbox one s case
Aayan Beast - 답글
Excuse me but is there an everyday item that I can use to open the bottom of my Xbox one s with?
Brody Luce - 답글
CAUTION: Sheared off power and pairing switches when attempting to affix to panel.
Mark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 189
30일 전: 798
전체 시간: 63,129
