이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to remove the top panel of the interior case of the Xbox Box One S. This is necessary for the removal of either the hard drive, the disk drive, the heatsink/fan, the motherboard, or the power block.
필요한 것
Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
다른 11명이 해당 안내서를 완성하였습니다.
