소개
This guide is important because it is necessary to access certain components on the board that may need replacing.
Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Important!!
You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
I dont mind because it's my own Xbox, but what if it belonged to a customer?
Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
Do not remove the back panel from the metal housing by popping loose the “rivets” in Step 5 photo. Those are not rivets, they are melted post-end mounts in which the heads will break off and CAN NOT BE REPLACED by the do-it-yourself repairer (unless you want to try hot gluing the mounts back to the panel, but success is uncertain with this method). While doing my own tear-down following the photo examples, I thought the rear panel was meant to come off due to the photo of it laying next to the body in Step 7. This is inaccurate, and will most likely result in a loose fitting panel upon reassembly. The “rivets” no longer have a means to hold onto the metal body tray they came loose from. So you will have the panel relying on alignment back to the channel the tabs came out of in order to hold it to the back of your machine. Other than this issue, I was able to perform the tear-down without problem.
Gently separate the interior case from the white exterior case using the appropriate method.
To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
Some of my silver were gold screws, so just letting people know to look out for that!
Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
Do not disconnect the connector in the second image! There are tiny prongs that bend easily and if bent just a tad bit they will break off. I had first hand experience with this and I ended up breaking my Xbox because I could not put that cable back on.
Do not remove the cable!!!! You can change while the cables are plugged. It took 2 hours trying to put mm precisely all the little pins because of the removal of the cables.
Please update the post, I could easily end up as the Aaron, breaking the XBOX completly.
To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
Remove the four black 8 mm T-9 Torx screws lablelled "A1," "A2," "A3," and "A4."
The Black screws are T-8 Torx, not T-9!
I didnt see this before, so thankfully I was able to use T9 without stripping the screws!
IMPORTANT! You also need to remove the two T10 screws labeled B1 and B2 in order to remove the motherboard! I had to figure this out on my own.
다른 27명이 해당 안내서를 완성하였습니다.
댓글 6개
This guide is really missing alot between steps 13 and 14. There are two black panels that have to be removed(they’re in the teardown guide). One is on the front with with screws E1 ,E2, E3, E4. And theres another panel on the side with screws D1, D2, D3. Finally there are two more screws on the bottom that hold down the motherboard B1, and B2. Theres Also a black from in between the Fan and case that slides off too.
Yep, I was using this guide and realized that it is missing a few vital steps. Thank you Nathan.
If you have a multimeter could you please test the test points around the board and give me a list of a voltages?
fantastic! only issues that are missing, are mentioned in the comments above. I´d like to include that most of the exterior hardcase clips are made to be HELD in place. Which is why it´s a nuisanse to remove. So, newcomers be careful with it. otherwise you´ll easily break it.
Son los mejores
My xbox one s turns on, fan runs but no signal nor will not connect to controller.
I do have a faint burnt smell, any idea what could be at fault?
